Hi @rbertoletti . Please try this code. But it does not process patterns.
Sub main
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim oPane As BrowserPane = oDoc.BrowserPanes.Item("Model")
	Dim oOccs As ComponentOccurrences = oDef.Occurrences
	ReturnStep :
	For Each oOcc As ComponentOccurrence In oOccs
		Dim oRefDoc As Document = oOcc.Definition.Document
		If oRefDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject _
			Or Not oRefDoc.IsModifiable Then Continue For
		For Each oSubOcc As ComponentOccurrence In oOcc.SubOccurrences
		    Dim oSourceNode As BrowserNode
		    oSourceNode = oPane.GetBrowserNodeFromObject(oSubOcc)
		    Try : Call oPane.Reorder(oTargetNode, True, oSourceNode) : Catch : End Try
		Next
		oOcc.Delete()
	Next
	If HasSubAsm(oOccs) Then GoTo ReturnStep
End Sub
Private Function HasSubAsm(ByVal oOccs As ComponentOccurrences) As Boolean
	For i As Integer = 1 To oOccs.Count
		If oOccs(i).DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Return True
	Next i
	Return False
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
