That sounds like you may just need to use Documents.OpenWithOptions method, instead of the Documents.Open method.  Then, just before you call that method to run, you create a new NameValueMap object, and make sure you add an entry into it with the Name = "SkipAllUnresolvedFiles", and the Value = True.  Then supply that NameValueMap as the second (of 3) input being requested by the method.
Wesley Crihfield
(Not an Autodesk Employee)
