m_baczewski
in reply to: kv5053545
Give it a try as I mentioned, at this point it should go through all the dimensions and center their positions.
Sub Main()
        If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
        Dim oDDoc As DrawingDocument = ThisDoc.Document
        Dim oStMgr As DrawingStylesManager = oDDoc.StylesManager
        Dim oDimStyles As DimensionStylesEnumerator = oStMgr.DimensionStyles
        Dim oDimStyle As DimensionStyle = oDimStyles.Item("Default (ANSI)")
        oDimStyle.ArrowheadType = ArrowheadTypeEnum.kBlankArrowheadType
        oDimStyle.ArrowheadSize = 0.2286
        oDimStyle.ArrowheadHeight = 0.08
        oDimStyle.Extension = 0.4572
        oDimStyle.Gap = 0.000
        oDimStyle.Spacing = 0.000
        Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
        Dim oDStyle As DimensionStyle = oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.LinearDimensionStyle
        Dim sFontSize As String = oDStyle.TextStyle.FontSize
        Dim x As Double
        x = 0.25
        oDStyle.TextStyle.FontSize = x
        Dim oDimensions As DrawingDimensions
        oDimensions = oDDoc.ActiveSheet.DrawingDimensions
        Dim oDrawDim As DrawingDimension
        For Each oDrawDim In oDimensions
           If TypeOf oDrawDim Is LinearGeneralDimension
              Call oDrawDim.CenterText
           End If
        Next
End Sub
