cgoethalsFU8PY
213 Views, 2 Replies
Automatic 2D drawing for family table of ipart
Dear all,
I am looking for an ilogic code to do the following:
I have a 2D-drawing of a component which has a lot of variants. This component is the first member in the family table of an ipart.
Is there a possibility to copy this 2D-drawing, change its name to the part number of the following drawing in the family table, then replace all the views in the drawing by the views of the next drawing in the family table and save the drawing again? Is there a possibility to put this in a loop so that the ilogic code performs this action for all the members in the family table of my ipart?
Thank you very much for your insights!
Kind regards,
Cor
Hi @cgoethalsFU8PY . See the solution from @JhoelForshav  at this link. If you have any problems, don't hesitate, we will be happy to help.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Hi @Andrii_Humeniuk ,
I tried adapting the code so this would work for an idw-file but I am not succeeding in this. Could you help me out with this?
I used the code below.
Kind regards,
Cor
Sub main()
Dim oDrawing As DrawingDocument
oDrawing = ThisApplication.ActiveDocument
Dim oPath As String
oPath = "O:\Product Development\Inventor\Workspace\TEST_ILOGIC" 'Folder to save the drawings
Dim oView As DrawingView
Dim oDoc As Document
Dim oFactory As iPartFactory
For Each oView In oDrawing.ActiveSheet.DrawingViews
    oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
    On Error GoTo trynext
    oFactory = oDoc.ComponentDefinition.iPartMember.ParentFactory
    Exit For
trynext:
Next
    If oFactory Is Nothing = False Then
    Dim oRow As iPartTableRow
    For Each oRow In oFactory.TableRows
        On Error GoTo nextView
        If oView.ActiveMemberName <> oRow.MemberName Then oView.ActiveMemberName = oRow.MemberName
        Call oDrawing.Update
        Do While oView.IsUpdateComplete = False
            Call ThisApplication.UserInterfaceManager.DoEvents
        Loop
nextView:
    Next
    Call oDrawing.SaveAs(oPath & "\" & oRow.MemberName & ".idw", True)
Next
End If
End Sub
