08-18-2023
08:01 AM
- Mute
- Permalink
- Report
08-18-2023
08:01 AM
Couldn't find a code to update styles and refresh the Revision table using iLogic. Searched the forums and came up with the following:
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'update styles
Dim oCDs As ControlDefinitions = ThisApplication.CommandManager.ControlDefinitions
Dim oUpdateStyles As ControlDefinition = oCDs.Item("UpdateStylesCmd")
oUpdateStyles.Execute2(False)
AppActivate(ThisApplication.Caption)
System.Windows.Forms.SendKeys.SendWait("Y ")
Dim oRTBs As RevisionTables
oRTBs = oDrawDoc.ActiveSheet.RevisionTables
Dim oLocation As Point2d
'delete current table
If iProperties.Value("Project", "Revision Number") > 0 Then
oLocation = oRTBs.Item(1).Position
ActiveSheet.Sheet.RevisionTables.Item(1).Delete
Else
oLocation = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
End If
'add updated table
Dim oRTB As RevisionTable
oRTB = oRTBs.Add(oLocation)
' Codes used for inspiration:
' Update Styles: From WCrihfield (https://forums.autodesk.com/t5/Inventor-ilogic-And-vb-Net-forum/ilogic-code-To-update-styles-And-materials-To-Autodesk/m-p/12097339/highlight/true#M155179)
' Remove table: From Ktomberlin (https://forums.autodesk.com/t5/Inventor-ilogic-And-vb-Net-forum/delete-revision-table/m-p/3911995/highlight/true#M43747)
' Add table: From cody.evjen (https://forums.autodesk.com/t5/Inventor-ilogic-And-vb-Net-forum/ilogic-revision-table/m-p/5591728/highlight/true#M55303)Just to share back to you all.
Kind regards,
Alexander Boogaard
