ober2558
in reply to: FINET_Laurent
This code works well, except the files I am looking to use for this list are under the structural shape category and I have them set up with a user input length. This user input length is then added to the name of the file and therefore variable. (i.e. if 50mm is chosen, the name will be X 25-25 Profile 50, if 100mm is chosen, the name will be X 25-25 Profile 100) So therefore this code will not work entirely unless I manually input the names of each 1 mm variation. I can do this but I believe it will take more time than its worth. Is there a way to add them by "Name contains ___" such as "X 25-25 Profile" committing the variable length? If you need more clarification let me know.
