08-17-2023
06:47 AM
- Mute
- Permalink
- Report
08-17-2023
06:47 AM
In order for the program not to count specific components, it is necessary to somehow explain it to it. For example: for each CC component, a message will appear with the question "Calculate the mass of the component: CC Part 2" (Yes/No), or in the code, create a list with the names of components that do not need to be calculated (for this you need all the names of the components) or you can specify a specific characteristic that you need bolts only.
First, explain how you want the code to work.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
