@JelteDeJong
You are ALMOST right
The setting seems to be saved in AddInLoadRules-file ... BUT not XML (located under ... \AppData\Local\Autodesk\<Inventor VERSION>\Preferences\)
It is about extension-less AddInLoadRules-file located at ... \AppData\Roaming\Autodesk\<Inventor VERSION>\Addins\
PS:
I wish I knew the format of the file to not delete it completely but rather modify a bit (in part related to my particular addin).
Please vote for Inventor-Idea Text Search within Option Names
