- Mute
- Permalink
- Report
I've developed an add-in and now try to do my best on describing its usage.
I'd like to know how can I reset the unblock of the Add-In (I'd like to capture the video from the scratch but Inventor doesn't show the initial pop-up message warning the add-in from untrusted publisher was blocked)?
I believe there is some Add-In manager settings stored either in Inventor profile or registry. Any ideas?
Please vote for Inventor-Idea Text Search within Option Names
- Mute
- Permalink
- Report
Im not sure about this but you might want to have a look at the "AddInLoadRules.xml". You can find a bit more info about this file in this blog post "Add-In security in Inventor". If I'm correct you just need to delete that file to get what you want. (Make a backup of files before you delete them.)
Jelte de Jong
Blog: hjalte.nl - github.com
- Mute
- Permalink
- Report
You are ALMOST right
The setting seems to be saved in AddInLoadRules-file ... BUT not XML (located under ... \AppData\Local\Autodesk\<Inventor VERSION>\Preferences\)
It is about extension-less AddInLoadRules-file located at ... \AppData\Roaming\Autodesk\<Inventor VERSION>\Addins\
PS:
I wish I knew the format of the file to not delete it completely but rather modify a bit (in part related to my particular addin).
