WCrihfield
in reply to: mwilsonUG99E
Hi @mwilsonUG99E.  Here is just a partial example iLogic code that points out where all the title block definition related stuff is.
Sub Main
	If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
	Dim oDDoc As DrawingDocument = ThisDoc.Document
	Dim oTBDefs As TitleBlockDefinitions = oDDoc.TitleBlockDefinitions
	If oTBDefs.Count = 0 Then Exit Sub
	Dim oFirstTBDef As TitleBlockDefinition = oTBDefs.Item(1)
	Dim oSheets As Inventor.Sheets = oDDoc.Sheets
	For Each oSheet As Inventor.Sheet In oSheets
		If oSheet.TitleBlock IsNot Nothing Then
			Dim oSheetTB As TitleBlock = oSheet.TitleBlock
			Dim oTBDef As TitleBlockDefinition = oSheetTB.Definition
			'and so on
		End If
	Next 'oSheet
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) :thumbs_up:.
Wesley Crihfield
(Not an Autodesk Employee)
