ahh, apologies. I want it to display what the item number is of that component, in the assembly it is in. So if you look at the pic, the top one is correct, showing POS9 as it is item 9 in the structure.
The one below it shows POS1, as it only selected the first digit of ItemNumber "10". And because I simply multiplied the indent number by two to pick the right number, all other ones are off after this one too.
