I think this is due to the fact that your assembly contains components that cannot be edited, for example: content center components. I added a check (line 23), if it doesn't help then put the code section (lines 31 - 36) in a Try-Catch.
Sub Main
	Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
	Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	Dim oCustom As PropertySet = oAsmDoc.PropertySets.Item("Inventor User Defined Properties")
	Dim oTekNum As String
	Try : oTekNum = oCustom("TekNum").Value
	Catch : oTekNum = "" : End Try
	Dim oBOM As BOM = oAsmDef.BOM
	oBOM.StructuredViewEnabled = True
	oBOM.StructuredViewFirstLevelOnly = False
	Dim oBOMView As BOMView = oBOM.BOMViews(2) 'Structured view
	Call RecursiveCheckAndSetProps(oBOMView.BOMRows, oTekNum, 0)
End Sub
Private Sub RecursiveCheckAndSetProps(ByVal oRowsElements As BOMRowsEnumerator,
										ByVal oTekNum As String,
										ByRef indent As Integer)
	For Each oBOMRow As BOMRow In oRowsElements
		Dim oCompDef As ComponentDefinition = oBOMRow.ComponentDefinitions.Item(1)
		Dim oDoc As Document = oCompDef.Document
		If Not oDoc.IsModifiable Then Continue For
		'by multiplying by two, the itemnumber dodges the periods in the expanded part number.
		Dim oBOMItemNumber As String = oBOMRow.ItemNumber(indent*2)
	    Dim oCustom As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
		Dim oBOMNumb, oSamenstelling As Inventor.Property
		Try : oBOMNumb = oCustom("BOM Number") : oBOMNumb.Value = oBOMItemNumber
	    Catch : oBOMNumb = oCustom.Add(oBOMItemNumber, "BOM Number") : End Try
		Try : oSamenstelling = oCustom("Samenstelling")
		Catch : oSamenstelling = oCustom.Add("", "Samenstelling") : End Try
		oSamenstelling.Value = oTekNum & " POS" & oBOMNumb.Value
		If Not oBOMRow.ChildRows Is Nothing Then
			Call RecursiveCheckAndSetProps(oBOMRow.ChildRows, oCustom("TekNum").Value, indent+1)
		End If
	Next
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
