So what was missing was to open the document and then set the material. Trying to set the material without opening was not working.
Sub Main()
	Dim oADOC As Inventor.Document = ThisDoc.Document
	If oADOC.DocumentType <> kAssemblyDocumentObject Then
		MessageBox.Show("This rule cannot be executed in this file type.", "iLogic")
	Exit Sub
	End If
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsm, "FG Member Material Changer") 'Make this a single transaction
	Dim oAL_List As New ArrayList
	Dim lib_List As New ArrayList
	For Each oAL As AssetLibrary In ThisApplication.AssetLibraries
		If InStr(oAL.DisplayName , "Material") <> 0 Then
			oAL_List.Add(oAL.DisplayName)
		End If
	Next
	Dim oALSelect As String = InputListBox("Select Asset Library", oAL_List, oAL_List(0), "Change Part Material", "Available Selections")
	If oALSelect Is Nothing Then Exit Sub
	Dim oLib As AssetLibrary = ThisApplication.AssetLibraries(oALSelect)
	For Each libAsset In oLib.MaterialAssets
		lib_List.Add(libAsset.DisplayName)
	Next
	lib_List.Sort
	Dim oLibAssetSel As String = InputListBox("Select Material", lib_List, lib_List(0), "Change Part Material", "Available Selections")
	If oLibAssetSel Is Nothing Then Exit Sub
	For Each oDoc As Document In oAsm.AllReferencedDocuments 'Traverse all referenced documents
		If oDoc.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}") _	'Frame generator component
			AndAlso oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject _'Part
			AndAlso oDoc.IsModifiable _	'Modifiable
			AndAlso oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0 'Exists in assembly (not derived base component)
			Dim oPartDoc As PartDocument  = ThisApplication.Documents.Open(oDoc.FullFileName,False)
			Dim libMaterial As MaterialAsset
			Try
			 	libMaterial = oPartDoc.MaterialAssets.Item(oLibAssetSel)
			Catch
				libMaterial = oLib.MaterialAssets.Item(oLibAssetSel)
				libMaterial.CopyTo(oPartDoc)
			End Try
			oPartDoc.ActiveMaterial = libMaterial
			oPartDoc.Update
			oPartDoc.Close(True)
		End If
	Next
	oTransaction.End
End Sub
Regards
Alan
