08-09-2023
08:37 AM
- Mute
- Permalink
- Report
08-09-2023
08:37 AM
Your help is much appreciated.
I've modified the code a bit, namely removing this line entirely, as it was conflicting with some the code above it:
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
I've also remedied library setting issue by removing the second line:
Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item(oLib)
Now I'm just left with one error, and it is generated whenever the rule runs this line of code:
If I edit out this line, the code runs but doesn't set the material of the Frame Generator components.
oDoc.ActiveMaterial = oDoc.MaterialAssets.Item(MaterialName)
I've been looking around online to see if I can find some documentation on how to clear this Member not found error, but I've not come across much.
This is what my block looks like now:
Option Explicit On
Sub Main()
Dim oADOC As Inventor.Document = ThisDoc.ModelDocument
If oADOC.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("This rule cannot be executed in this file type.", "iLogic")
Exit Sub
End If
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsm, "FG Member Material Changer") 'Make this a single transaction
Dim oAL_List As New ArrayList
Dim lib_List As New ArrayList
For Each oAL As AssetLibrary In ThisApplication.AssetLibraries
If InStr(oAL.DisplayName , "Material") <> 0 Then
oAL_List.Add(oAL.DisplayName)
End If
Next
Dim oALSelect As String = InputListBox("Select Asset Library", oAL_List, oAL_List(0), "Change Part Material", "Available Selections")
If oALSelect Is Nothing Then Exit Sub
Dim oLib As AssetLibrary =ThisApplication.AssetLibraries(oALSelect)
For Each libAsset In oLib.MaterialAssets
lib_List.Add(libAsset.DisplayName)
Next
lib_List.Sort
Dim oLibAssetSel As String = InputListBox("Select Material", lib_List, lib_List(0), "Change Part Material", "Available Selections")
If oLibAssetSel Is Nothing Then Exit Sub
For Each oDoc As Document In oAsm.AllReferencedDocuments 'Traverse all referenced documents
If oDoc.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}") _ 'Frame generator component
AndAlso oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject _'Part
AndAlso oDoc.IsModifiable _ 'Modifiable (not reference skeleton)
AndAlso oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0 'Exists in assembly (not derived base component)
Dim MaterialName As String = oLibAssetSel
Try
Dim localMaterial As MaterialAsset = oDoc.MaterialAssets.Item(MaterialName)
Catch
Dim libMaterial As MaterialAsset = oLib.MaterialAssets.Item(MaterialName)
libMaterial.CopyTo(oDoc)
End Try
iLogicVb.UpdateWhenDone = True
End If
Next
oTransaction.End
End Sub
