- Mute
- Permalink
- Report
Hi there! my first ever post here so apologies if I mess something up.
I am trying to automatically fill in an iproperty in all sub-assemblies, which refers to the assembly above it, displaying the higher assembly's drawing number (TekNum), aswell as the position of the sub-assembly in the parts list of the assembly above it.
I have been lurking on these forums for a little while now, so I have some general understanding of how this all works, but I am by no means competent in ilogic, or vb.net or anything.
I can usually manage by stealing some code from here and there, an provisorically tying them together with the little coding I dó understand ![]()
That said, here's what I have so far, it gives me a BOM item number, and the "sub traverseassembly" part, plops it together with TekNum of the assembly it's being run in, into the Iproperties of the underlying components.
Sub Main Dim oAssemblyDocument As AssemblyDocument oAssemblyDocument = ThisDoc.Document Dim oAssemblyComponentDefinition As AssemblyComponentDefinition oAssemblyComponentDefinition = oAssemblyDocument.ComponentDefinition ''Get Name of Active LOD 'NameActiveLOD = oAssemblyComponentDefinition.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name ''Active Master LOD 'oAssemblyComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations(1).Activate Dim oBOM As BOM oBOM = oAssemblyComponentDefinition.BOM oBOM.StructuredViewEnabled = True oBOM.StructuredViewFirstLevelOnly = False Dim oBOMView As BOMView oBOMView = oBOM.BOMViews(2) 'Structured view Call RecursiveCheckAndSetProps(oBOMView.BOMRows, 0) Call TraverseAssembly(oAssemblyDocument.ComponentDefinition.Occurrences) 'Reactive original LOD 'oAssemblyComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations(NameActiveLOD).Activate End Sub Sub RecursiveCheckAndSetProps(ByVal oRowsElements As BOMRowsEnumerator, indent As Integer) On Error Resume Next For Each oBOMRow As BOMRow In oRowsElements Dim oComponentDefinition As ComponentDefinition oComponentDefinition = oBOMRow.ComponentDefinitions.Item(1) Dim oBOMItemNumber As String oBOMItemNumber = oBOMRow.ItemNumber(indent*2) ' by multiplying by two, the itemnumber dodges the periods in the expanded part number. Dim rDoc As Document = oComponentDefinition.Document Call Check_Prop(rDoc,oBOMItemNumber) If Not oBOMRow.ChildRows Is Nothing Then Call RecursiveCheckAndSetProps(oBOMRow.ChildRows,indent+1) End If Next End Sub Sub Check_Prop(rDoc As Document,oBOMItemNumber As String) Dim oComponentDefinitionPropertySet As PropertySet oComponentDefinitionPropertySet = rDoc.PropertySets.Item("Inventor User Defined Properties") 'custom property tab Try 'if already exists then set it oComponentDefinitionPropertySet.Item("BOM Number").Value = oBOMItemNumber Catch ex As Exception 'else add it oComponentDefinitionPropertySet.Add(oBOMItemNumber, "BOM Number") End Try End Sub Sub TraverseAssembly(oOccs As ComponentOccurrences) ' Iterate through all of the occurrence in this collection Dim oOcc As ComponentOccurrence For Each oOcc In oOccs Try If iProperties.Value(oOcc.Name, "Custom", "Samenstelling") = "" Then iProperties.Value(oOcc.Name, "Custom", "Samenstelling") = iProperties.Value("Custom", "TekNum") & " POS" & iProperties.Value(oOcc.Name, "Custom", "BOM Number") End If Catch 'Logger.Info("Error in {0}", oOcc.Name) 'enable to show which components throw an error End Try ' Recursively call sub if needed If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then Call TraverseAssembly(oOcc.SubOccurrences) End If Next End Sub
Ideally, "sub traverseassembly" would take the "TekNum" of every assembly, and put it in all underlying occurences. That would only require that part be changed.
The goal at this moment is to only need to run the rule in the very top (main) assembly.
If there's a way easier way to do this (I honestly expect there to be), then that is ofcourse also very welcome ![]()
