@A.Acheson,
Thank you for your reply.
I've taken the snippet you've provided and added it to my document loop of my assembly and modified it a bit to match what I'm wanting.
I do want the user running the code to select the material library and material name in the assembly environment through the input list boxes created by the block.
The only issue I'm running into is getting the user's selection from the assembly to the part.
However, when I run the newly modified code I'm presented with an error.
Please see attached for the error.
I've also pasted the modified code below.
I feel like I'm close now, thanks to your contributions (I realized that some of the code I've copied is actually some of your older works).
Sub Main()
	oADOC = ThisDoc.ModelDocument
	If oADOC.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("This rule cannot be executed in this file type.", "iLogic")
	Exit Sub
	End If
	Dim oAsm As AssemblyDocument = ThisDoc.Document
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oAsm, "FG Member Material Changer") 'Make this a single transaction
	Dim oAL_List As New ArrayList
		Dim lib_List As New ArrayList
		For Each oAL As AssetLibrary In ThisApplication.AssetLibraries
			If InStr(oAL.DisplayName , "Material") <> 0 Then
				oAL_List.Add(oAL.DisplayName)
			End If
		Next
		Dim oALSelect As String = InputListBox("Select Asset Library", oAL_List, oAL_List(0), "Change Part Material", "Available Selections")
		If oALSelect Is Nothing Then Exit Sub
		Dim oLib As AssetLibrary =ThisApplication.AssetLibraries(oALSelect)
		For Each libAsset In oLib.MaterialAssets
			lib_List.Add(libAsset.DisplayName)
		Next
		lib_List.Sort
		Dim oLibAssetSel As String = InputListBox("Select Material", lib_List, lib_List(0), "Change Part Material", "Available Selections")
		If oLibAssetSel Is Nothing Then Exit Sub
	For Each oDoc As Document In oAsm.AllReferencedDocuments 'Traverse all referenced documents
		If oDoc.DocumentInterests.HasInterest("{AC211AE0-A7A5-4589-916D-81C529DA6D17}") _	'Frame generator component
			AndAlso oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject _'Part
			AndAlso oDoc.IsModifiable _	'Modifiable (not reference skeleton)
			AndAlso oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count > 0 'Exists in assembly (not derived base component)
				Dim oDoc1 As PartDocument = ThisApplication.ActiveDocument
					Dim assetLib As AssetLibrary  = ThisApplication.AssetLibraries.Item(oLib)
					ThisApplication.ActiveMaterialLibrary = assetLib
					Dim MaterialName As String = oLibAssetSel
					Try
					Dim localMaterial As MaterialAsset = oDoc1.MaterialAssets.Item(MaterialName)
					Catch
					Dim libMaterial As MaterialAsset = assetLib.MaterialAssets.Item(MaterialName)
					libMaterial.CopyTo(oDoc1)
					End Try
					oDoc1.ActiveMaterial = oDoc1.MaterialAssets.Item(MaterialName)
				iLogicVb.UpdateWhenDone = True
		End If
	Next
	oTransaction.End
End Sub
