- Mute
- Permalink
- Report
Hi @ngnam1988. Here is an iLogic rule containing a couple of pretty helpful custom Functions to help you find those BrowserNode objects. Once you have tried it out, you can change the way you set the True/False (expanded/not expanded) setting however you want. I'm using condensed Try...Catch blocks in this rule, just in case the node is either not found, or not currently visible. If you can't see it on your screen, then you will likely not be able to expand it. There are also other useful routines for recursively searching or processing a BrowserNode tree.
Sub Main
Dim oDoc As Document = ThisDoc.Document
Dim oModelPane As BrowserPane = GetModelBrowserPane(oDoc)
Dim oTopNode As BrowserNode = oModelPane.TopNode
Dim oBlocksNode As BrowserNode = RecursivelyGetBrowserNodeByName(oTopNode.BrowserNodes, "Blocks", True)
Try : oBlocksNode.Expanded = True : Catch : End Try
Dim oSolidBodiesNode As BrowserNode = RecursivelyGetBrowserNodeByName(oTopNode.BrowserNodes, "Solid Bodies", True)
Try : oSolidBodiesNode.Expanded = True : Catch : End Try
Dim oViewNode As BrowserNode = RecursivelyGetBrowserNodeByName(oTopNode.BrowserNodes, "View:", True)
Try : oViewNode.Expanded = True : Catch : End Try
Dim oAnnotationsNode As BrowserNode = RecursivelyGetBrowserNodeByName(oTopNode.BrowserNodes, "Annotations", True)
Try : oAnnotationsNode.Expanded = True : Catch : End Try
Dim oOriginNode As BrowserNode = RecursivelyGetBrowserNodeByName(oTopNode.BrowserNodes, "Origin", True)
Try : oOriginNode.Expanded = True : Catch : End Try
End Sub
Function GetModelBrowserPane(oDoc As Document) As BrowserPane
For Each oPane As BrowserPane In oDoc.BrowserPanes
If oPane.BuiltIn And oPane.TreeBrowser And _
(oPane.InternalName = "AmBrowserArrangement" Or _
oPane.InternalName = "DlHierarchy" Or _
oPane.InternalName = "PmDefault") Then Return oPane
Next : Return Nothing
End Function
Function RecursivelyGetBrowserNodeByName(oNodes As Inventor.BrowserNodesEnumerator, sNodeName As String, _
Optional bUseStartsWith As Boolean = False) As Inventor.BrowserNode
If oNodes Is Nothing OrElse oNodes.Count = 0 Then Return Nothing
For Each oNode As Inventor.BrowserNode In oNodes
If bUseStartsWith = True Then
If oNode.BrowserNodeDefinition.Label.StartsWith(sNodeName) Then Return oNode
Else
If oNode.BrowserNodeDefinition.Label = sNodeName Then Return oNode
End If
If oNode.BrowserNodes.Count > 0 Then RecursivelyGetBrowserNodeByName(oNode.BrowserNodes, sNodeName, bUseStartsWith)
Next 'oNode
Return Nothing
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
