- Mute
- Permalink
- Report
I know this is old, but seeing as this was a prominent answer in my search I felt I needed to supply an answer.
Yes you can.
Search how to send values to an ExternalRule using a NameValueMap.
Dim Map As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
You send the value by the following;
Map.Add("NameofValue", Value)
Map.Add("NameofValue2", Value2), etc.
Call your external Rule via
ilogicVb.RunExternalRule("ExternalRuleName",Map)
In the external Rule you access the Map values from
NameofValue = RuleArguments("NameofValue")
To return a new value to the original Rule use the following;
RuleArguments.Arguments.Value("NameofValue") = NewValue
When you return to the Calling Rule, use the following;
NewValue =Map.Value("NameofValue")
Please exercise caution with copy paste of my code. I typed this in a hurry and nothing was a copy paste from working code. But I hope this will help someone out someday. (Most likely myself if I'm honest)
