@mindaV3J2J ,
This VBA example will open all the assemblies in a folder, and then close them. Add your DXF code where indicated.
Sub FindFilesWithComment()
    sName = ThisApplication.ActiveDocument.FullFileName
    Dim filesystem As Object
    Set filesystem = CreateObject("Scripting.FilesystemObject")
    Dim ActiveDoc As Document
    Set ActiveDoc = ThisApplication.ActiveDocument
    Dim FolderPath As String
    FolderPath = BrowseForFolder()
    If FolderPath = "" Then Exit Sub
    Dim oFSO As Object
    Dim oFolder As Object
    Dim oFile As Object
    Dim oFiles As Object
    Dim oFileNames As String
    oFileNames = "Files with comments: " & oComment
    Set oFSO = CreateObject("Scripting.FileSystemObject")
    Set oFolder = oFSO.GetFolder(FolderPath)
    For Each oFile In oFolder.Files
        If LCase(oFSO.GetExtensionName(oFile.Name)) = "iam" Then
            sFilename = FolderPath & "\" & oFile.Name
            Dim oAsmDoc As AssemblyDocument
            'set option to false to open invisible and run faster
            Set oAsmDoc = ThisApplication.Documents.Open(sFilename, True)
            MsgBox (oAsmDoc.FullFileName)
            Dim oRefDocs As DocumentsEnumerator
            Set oRefDocs = oAsmDoc.AllReferencedDocuments
            Dim oRefDoc As Document
            For Each oRefDoc In oRefDocs
                'put your DXF code here
            Next oRefDoc
            If Not ActiveDoc Is oAsmDoc Then oAsmDoc.Close (True) 'true = skip save
        End If
    Next oFile
End Sub
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
    Dim ShellApp As Object
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
    On Error Resume Next
    BrowseForFolder = ShellApp.self.Path
    On Error GoTo 0
    Set ShellApp = Nothing
    Select Case Mid(BrowseForFolder, 2, 1)
    Case Is = ":"
        If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
    Case Is = "\"
        If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
    BrowseForFolder = ""
End Function
