Maxim-CADman77
337 Views, 4 Replies
Conditional control of the assembly component presence with iLogic
I'd like to know how to control (place/delete) assembly component by means of iLogic.
Let's take standard scissors.iam (see attached, saved with Inventor 2022.5) as a simplest sample.
I've added 'Spring_Exist' parameter (Boolean).
What would be the minimal iLogic-rule code to add/remove Scissors_spring component based on the value of my parameter?
PS:
I don't interested in old-school methods (like switching Visibility On/Off, Enabled/Disabled, Suppress/Unsuppress).
PPS:
I do see the relevant sample BrewMain-Drawing-ModelState.zip at https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/3gnm93P9sPAWE6vndk7fjq.html but I'd like a simpler one.
Please vote for Inventor-Idea Text Search within Option Names
