mich_rymut
in reply to: mich_rymut
i have managed to get it to work.
I followed this guide to install vault API and all the libraries:
https://www.autodesk.com/autodesk-university/class/iLogic-and-Vault-Vault-and-iLogic-2020#handout
And i got it working with this code:
AddReference "QuickstartiLogicLibrary.dll"
Sub
Main() Dim ex As Exception break 'the rule can be run on assembly files only If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Logger.Info("Rule iLogicVault_Generate_stp applies to assembly documents only. Exited without action.") Return End If 'enable iLogicVault commands and validate user's login state Dim iLogicVault As New QuickstartiLogicLibrary.QuickstartiLogicLib If iLogicVault.LoggedIn = False Logger.Error("Not Logged In to Vault! - Login first and repeat executing this rule.") Exit Sub End If Dim ass As AssemblyDocument = ThisApplication.ActiveDocument Dim oSelSet As SelectSet = ass.SelectSet If oSelSet.Count = 0 Then MessageBox.Show("Choose files before running the rule", "Error") Exit Sub End If Dim i As Integer = 0 Dim result As Boolean Dim Occ As ComponentOccurrence For Each Occ In oSelSet Dim OccDoc As Document = Occ.Definition.Document 'Get the file path and name with extension oName = System.IO.Path.GetFullPath(OccDoc.FullFileName) ' change extensions by removing last 3 characters and adding stp lenght_oName = oName.Length lenght_we = lenght_oName - 3 oName_we = oName.remove(lenght_we) oName_ne = oName_we & "stp" oNewName = oName_ne result = ExportFiles(OccDoc, oNewName) If result = True Then i = i + 1 End If Next MessageBox.Show("Number of saved files: " & i, "Result") End Sub Function ExportFiles(doc As Document, NewFileName As String) As Boolean ' Get the STEP translator Add-In. Dim oSTEPTranslator As TranslatorAddIn oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}") If oSTEPTranslator Is Nothing Then MsgBox("Could not access STEP translator.") ExportFiles = False Exit Function End If oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oData = ThisApplication.TransientObjects.CreateDataMedium oData.FileName = NewFileName oNewName = NewFileName If oSTEPTranslator.HasSaveCopyAsOptions(doc, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 'oOptions.Value("Author") = "" 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = "" 'oOptions.Value("Organization") = "" 'check if file exists and if it does, delete it. Dim oFileInfo As New System.IO.FileInfo(oNewName) Try If oFileInfo.Exists = True Then If (oFileInfo.Attributes) Then oFileInfo.Attributes = (oFileInfo.Attributes And Not oFileInfo.Attributes.ReadOnly) System.IO.File.Delete(oNewName) End If End If Catch End Try 'finally save step file oSTEPTranslator.SaveCopyAs(doc, oContext, oOptions, oData) ExportFiles = True ' export file to vault Dim iLogicVault As New QuickstartiLogicLibrary.QuickstartiLogicLib Dim mVaultPath As String = iLogicVault.ConvertLocalPathToVaultPath(oNewName) success = iLogicVault.AddFile(oNewName, mVaultPath, True) If (success <> True) Logger.Error("Failed to add/update stp file to Vault") Else Logger.Info("Stp file successfully created and uploaded to Vault.") End If End If End Function
