Curtis_Waguespack
in reply to: dleesuk
Hi @dleesuk
You can use something like this to find the largest rev letter.
I hope this helps.
Curtis
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oPartList As PartsList
oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
oMax = "A"
oRowMax = 1
' Iterate through the contents of the parts list
Dim i As Long
For i = 1 To oPartList.PartsListRows.Count
	'look at only the REVISION column
	oCell = oPartList.PartsListRows.Item(i).Item("REVISION")
	Dim letterarray As New ArrayList
	letterarray.Add(oCell.Value)
	letterarray.Add(oMax)
	letterarray.Sort
	oMax = letterarray.Item(1)
	If oCell.Value = oMax Then oRowMax = i
Next
MsgBox("Row " & oRowMax & " has the largest rev letter of " & _
oPartList.PartsListRows.Item(oRowMax).Item("REVISION").Value, , "iLogic")
