07-28-2023
01:50 AM
- Mute
- Permalink
- Report
07-28-2023
01:50 AM
Solved it with a test in ilogic.
Still wonder if this is the best way to do it.
I get the direction from line.geometry.direction
This is a unitvector which has length value = 1
I cast it AsVector and then I scale it by 5 and i get 50mm
Dim odoc As PartDocument = ThisDoc.Document Dim osketch As PlanarSketch = odoc.ComponentDefinition.Sketches.Item(1) Dim line As Inventor.SketchLine = osketch.SketchLines(1) Dim osel As Inventor.SelectSet = odoc.SelectSet Dim opoint As Inventor.SketchPoint = line.StartSketchPoint Dim vec As Inventor.Vector2d = line.Geometry.Direction.AsVector vec.ScaleBy(5) Dim tg As TransientGeometry = ThisApplication.TransientGeometry Dim holepoint2d As Inventor.Point2d = tg.CreatePoint2d(opoint.Geometry.x+vec.X, opoint.Geometry.y+vec.Y) Dim skpnt As SketchPoint = osketch.SketchPoints.Add(holepoint2d, True)
