- Mute
- Permalink
- Report
Understanding Vector2D and UnitVector2D
I have a problem understanding how to use vectors in a sketch.
Situation:
My code creates a sketch in sheetmetals, projects the edges and then offsets those lines.
Currently, I want to make a centermark pattern on the offseted lines.
As a mechanical engineer, for me, a vector has a direction and a magnitude
But when you do transientGeometry.CreateVector2d then you have to fill in X and Y coords.
My brain says with that input you get a point, not a vector
And if i search in:
Dim vec as vector2d
you can find: vec.length
How does the vector get length from that input
Or is this perhaps an array of 2 x points and 2 y points? (but how is that done)
Also what is UnitVector2d compared to vector2d
I got weird results and I'm obviously missing some basics.
Help
So imagine what I want to create:
I have a sketchline, with any angle, and any length (But its always a straight line, no arc entities etc)
Based on the length of the line I determine how many holes, distance between holes and distance from edges. (got that working)
Then i want to create sketchpoints, measured from the startpoint of the sketchline in the direction of the sketchline (im stuck here)
