- Mute
- Permalink
- Report
Hi
I'm looking to open a drawing via the Application.Documents.Open method, or else something effectively the same, that can get me the drawing document from within a different document, only with updates deferred.
I would like to skip resolving files/opening subdocuments for a particular script because it has a huge impact on performance (lots of files, no subdocument information needed).
Is there any way to do this?
EDIT: using Application.AssemblyOptions.DeferUpdate seems to help, but there aren't equivalent properties for the DrawingOptions or PartOptions classes, so I'm still curious to know if there's anything else that can be done.
- Mute
- Permalink
- Report
Hi @meGVGMF . You need to write the path to your file in line 3 - "FullFileName"
Dim oNVM As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
oNVM.Add("DeferUpdates", True)
Dim oDDoc As DrawingDocument = ThisApplication.Documents.OpenWithOptions("FullFileName", oNVM)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
- Mute
- Permalink
- Report
But what would be the way to turn this off? Do I need to reopen the document with the option unset, or can I do it through the document object somehow?
Would that be through `oDoc.DrawingSettings.DeferUpdates` ?
- Mute
- Permalink
- Report
Yes, your guess is correct. In order for the document to be updated again, you need DeferUpdates = False.
oDoc.DrawingSettings.DeferUpdates = False
- Mute
- Permalink
- Report
