Is there a way to get the numeric value from the InputBox and start PartsListNumber from that or add it to the PartsListNumber? I found some code that takes all of the parts lists from a DWG and creates a new tab in Excel for each instance but I would like to have some control over the numbering of the tabs so that the tabs align with the actual location/floor level on our project. See the code below.
		oInput = InputBox("Input the first floor level number below", "First Floor Level", "")
		numericCheck = IsNumeric(oInput)
		If numericCheck = True Then
		MessageBox.Show("Input is numeric", "iLogic")
		Else
		MessageBox.Show("Input is NOT numeric.", "iLogic")
		End If
        'specify the start cell
        oOptions.Value("StartingCell") = "A" & startRow
        'specify the XLS tab name
        'here the file name is used
        oOptions.Value("TableName") = "Embeds For Level-" & PartsListNumber 'without extension
        'choose to include the parts list title row
        'in this example "Ye Old List of Parts" is written to the StartingCell
        oOptions.Value("IncludeTitle") = False
        'choose to autofit the column width in the xls file
        oOptions.Value("AutoFitColumnWidth") = True
        ' export the Partslist to Excel with options
        oPartslist.Export(fileName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
        PartsListNumber = PartsListNumber + 1
