WCrihfield
in reply to: ktucker86UDQ
Hi @ktucker86UDQ.  Just so you are aware, the first 3 WorkPlanes, and the first 3 WorkAxes, and the first 1 WorkPoint in every model type document (parts & assemblies) are the ones that belong to the origin of that model.  They will be in the same order as you see them in the model tree.  The ones after that will be user defined ones.  There is a property you can check too (IsCoordinateSystemElement).
Wesley Crihfield
(Not an Autodesk Employee)
