38620079
328 Views, 4 Replies
怎么回事?图纸上的代码出错了,谁能告诉我该怎么做?
Sub Main() Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument Dim baseScale As Double = oDrawingDoc.ActiveSheet.DrawingViews.Item(1).Scale For Each oView As DrawingView In oDrawingDoc.ActiveSheet.DrawingViews oView.Scale = baseScale Next End Sub
38620079
in reply to: 38620079
What's going on? The code is running wrong in the drawing, who can tell me what to do?
FINET_Laurent
Make sure the view you are chaning the scale is a main view and not an projected view, section views, etc. since those views scale are linked to the main ones :
Sub Main()
		If oView.Type <> DrawingViewTypeEnum.kStandardDrawingViewType Then Continue For
	Next
End Sub
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
vpeuvion
Hi, you can try this:
Sub Main()
		If oView.ViewType = 10501 Then oView.Scale = baseScale
	Next
End Sub
 Vincent.
38620079
in reply to: FINET_Laurent
噢!I see 谢谢
