07-03-2023
09:20 AM
- Mute
- Permalink
- Report
07-03-2023
09:20 AM
Hi @GosponZ
If I understand correctly, you want to use the part number as the name of each occurrence in the assembly.
Something like this should do the trick ![]()
Class ThisRule Sub Main iLogicvb.UpdateWhenDone = True Dim def As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition For Each oOcc As ComponentOccurrence In def.Occurrences TraverseAndSetNames(oOcc) Next End Sub Sub RenameOcc(oOcc As ComponentOccurrence) Dim partNum As String = oOcc.Definition.Document.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value If oOcc.Parent.Occurrences.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = partNum Or x.Name.StartsWith(partNum & ":")) Is Nothing oOcc.Name = partNum ElseIf oOcc.Parent.Occurrences.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = partNum AndAlso x IsNot oOcc) Is Nothing oOcc.Name = partNum Else Dim i As Integer = 1 For Each eOcc As ComponentOccurrence In oOcc.Parent.Occurrences If eOcc.Name = partNum Or eOcc.Name.StartsWith(partNum & ":") If eOcc IsNot oOcc Dim oName As String = partNum & ":" & i Dim existingOcc As ComponentOccurrence = oOcc.Parent.Occurrences.OfType(Of ComponentOccurrence).FirstOrDefault(Function(x) x.Name = oName) If existingOcc IsNot Nothing Then existingOcc.Name = oName & "_temp" eOcc.Name = oName i += 1 End If End If Next oOcc.Name = partNum & ":" & i End If End Sub Sub TraverseAndSetNames(oOcc As ComponentOccurrence) RenameOcc(oOcc) If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject If oOcc.IsiAssemblyMember Dim iAssyMember As iAssemblyMember = oOcc.Definition.iAssemblyMember Dim def As AssemblyComponentDefinition = iAssyMember.ReferencedDocumentDescriptor.ReferencedDocument.ComponentDefinition For Each sOcc As ComponentOccurrence In def.Occurrences TraverseAndSetNames(sOcc) Next iAssyMember.ReferencedDocumentDescriptor.ReferencedDocument.Save2(True) Else For Each sOcc As ComponentOccurrence In oOcc.SubOccurrences TraverseAndSetNames(sOcc) Next End If End If End Sub End Class
I had to add numbering to the names if there are multiple occurrences in the same assembly with the same part number. I used a colon as a separator for this (<Part Number>:<Number>). If you use part numbers containing colons maybe use another character for the saparation ![]()
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
