philippe.lagrue
in reply to: ts2.cad3
Thank you for the answer.
Here is the result (components are partially renamed) :
And in fact the program is aborted by this error
The code modified as you suggest :
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	End If
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	'Dim oOcc As ComponentOccurrence
	'Start a Transaction to bundle all the name changes into a single item in the 'Undo' menu.
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oADoc, "Rename Components")
	'rename all comps in top level first
	For Each oOcc In oADef.Occurrences
		RenameOcc(oOcc)
	Next
	'now try to rename comps at deeper levels
	For Each oOcc As ComponentOccurrence In oADef.Occurrences.AllReferencedOccurrences(asmDef).OfType(Of ComponentOccurrence)
		RenameOcc(oOcc)
	Next
	'end the Transaction
	oTransaction.End
End Sub
You can find the assembly in the link below.
