ts2.cad3
in reply to: philippe.lagrue
 try to use this Sub main instead:
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	End If
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
	'Dim oOcc As ComponentOccurrence
	'Start a Transaction to bundle all the name changes into a single item in the 'Undo' menu.
	Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oADoc, "Rename Components")
	'rename all comps
	For Each oOcc As ComponentOccurrence In oADef.Occurrences.AllReferencedOccurrences(asmDef).OfType(Of ComponentOccurrence)
	RenameOcc(oOcc)
Next
