06-30-2023
02:31 AM
- Mute
- Permalink
- Report
06-30-2023
02:31 AM
I have tried this code for renaming all components in an assembly :
Class ChgDisplayName Public name As String = "Part " Public cpt As Integer = 1 Sub Main If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE") Exit Sub End If Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition Dim oOcc As ComponentOccurrence 'Start a Transaction to bundle all the name changes into a single item in the 'Undo' menu. Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(oADoc, "Rename Components") 'rename all comps in top level first For Each oOcc In oADef.Occurrences RenameOcc(oOcc) Next 'now try to rename comps at deeper levels For Each oOcc In oADef.Occurrences If oOcc.SubOccurrences.Count > 0 Then 'it is a sub-assembly 'run 'recursive' sub here 'and supply the SubOccurrences to it Iterate(oOcc.SubOccurrences) End If Next 'end the Transaction oTransaction.End End Sub Sub RenameOcc(oComp As ComponentOccurrence) 'create new variable to enable 'Intellisense' recognition Dim oCO As ComponentOccurrence = oComp 'get the PN Dim oCODoc As Document = oCO.Definition.Document 'Dim oPN As String = oCODoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value Dim oPN As String = name & cpt 'check if PN is empty (not filled in) If oPN = "" Or oPN = " " Then MsgBox("Occurrence '" & oCO.Name & "' has an 'Empty' Part Number." & vbCrLf & _ "Leaving original component name as it was.", , "") 'oPN = oCO.Name Exit Sub End If 'attempt to rename the component Dim oWorked As Boolean = False Try oCO.Name = oPN Catch Dim oInt As Integer = 0 Do Until oWorked = True oInt = oInt + 1 Try oCO.Name = oPN & ":" & oInt oWorked = True Catch oWorked = False If oInt > 10 Then oWorked = True End If End Try Loop Catch MsgBox("Failed to rename: " & oCO.Name,,"") End Try If oWorked Then cpt += 1 End If End Sub Sub Iterate(oOccs As ComponentOccurrencesEnumerator) 'create new variable to enable 'Intellisense' recognition Dim oComps As ComponentOccurrencesEnumerator = oOccs Dim oCO As ComponentOccurrence 'try to rename all comps at this level first For Each oCO In oComps RenameOcc(oCO) Next 'now loop through again checking for SubOccurrences, then Iterate For Each oCO In oComps If oCO.SubOccurrences.Count > 0 Then 'it is a sub-assembly Iterate(oCO.SubOccurrences) End If Next End Sub End Class
But it don't work for internal parts of an iAssembly :
Do you know why ?
Is there a solution ?
