- Mute
- Permalink
- Report
Hi @dave_taylor. Below is an iLogic rule you can use to investigate what options are available by code when using one of the TranslatorAddin objects to Open/Import a non-native file. There is a very similar rule for getting the options for when you are exporting.
Sub Main
Dim oTranslator As TranslatorAddIn = Nothing
For Each oAppAddin As ApplicationAddIn In ThisApplication.ApplicationAddIns
If oAppAddin.DisplayName = "Translator: SolidWorks" Then oTranslator = oAppAddin
Next
If oTranslator Is Nothing Then Exit Sub 'it was not found
'specify the full path & file name of the file you want to Open or Import.
Dim sSolidWorksFile As String = "C:\Temp\MySWfile.sldprt"
LogTranslatorOptions(oTranslator, sSolidWorksFile)
End Sub
Sub LogTranslatorOptions(oTransAddIn As TranslatorAddIn, sFileName As String)
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
oDataMedium.FileName = sFileName
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kUnspecifiedIOMechanism
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
If oTransAddIn.HasOpenOptions(oDataMedium , oContext, oOptions) Then
Dim i As Integer = 1
For Each oPair In oOptions
Dim sName As String = oOptions.Name(i)
Dim oValue As Object = oOptions.Value(sName)
Logger.Info("Option Name = " & sName & vbCrLf & "Option Value = " & oValue.ToString)
i = i + 1
Next
End If
End Sub
And below is what I got in my iLogic Log window (I'm using Inventor Pro 2024).
INFO| 5: >>---------------------------
INFO|Option Name = EnableSaveComponentDuringLoad
Option Value = False
INFO|Option Name = SaveLocationIndex
Option Value = 2
INFO|Option Name = ComponentDestFolder
Option Value = C:\Temp\
INFO|Option Name = AssemDestFolder
INFO|Option Name = SaveAssemSeperateFolder
INFO|Option Name = AddFilenamePrefix
INFO|Option Name = FilenamePrefix
Option Value =
INFO|Option Name = AddFilenameSuffix
INFO|Option Name = FilenameSuffix
Option Value =
INFO|Option Name = EmbedInDocument
INFO|Option Name = SaveToDisk
INFO|Option Name = ImportSolid
Option Value = True
INFO|Option Name = ImportSurface
Option Value = True
INFO|Option Name = ImportWire
Option Value = True
INFO|Option Name = ImportWorkPlane
Option Value = True
INFO|Option Name = ImportWorkAxe
Option Value = True
INFO|Option Name = ImportWorkPoint
Option Value = True
INFO|Option Name = ImportMeshes
Option Value = True
INFO|Option Name = ImportValidationProperties
INFO|Option Name = CreateIFO
INFO|Option Name = ImportAASP
INFO|Option Name = ImportAASPIndex
Option Value = 0
INFO|Option Name = CreateSurfIndex
Option Value = 1
INFO|Option Name = GroupName
Option Value =
INFO|Option Name = GroupNameIndex
Option Value = 0
INFO|Option Name = ExplodeMSB2Assm
INFO|Option Name = ImportUnit
Option Value = 0
INFO|Option Name = CheckDuringLoad
INFO|Option Name = AutoStitchAndPromote
Option Value = True
INFO|Option Name = AdvanceHealing
INFO|Option Name = EdgeSplitAndMergeDisabled
INFO|Option Name = FaceSplitAndMergeDisabled
INFO|Option Name = AssociativeImport
INFO|Option Name = Selective Import
INFO|Option Name = Link Visibility
Option Value = True
INFO|Option Name = SaveInSubFolder
Option Value = True
INFO|Option Name = PathOption
Option Value = -1
INFO|Option Name = UserPath
Option Value =
Wesley Crihfield
(Not an Autodesk Employee)
