A.Acheson
in reply to: alex_vela10
Hi @alex_vela10
One method is to attach a leader at the level you need and then read the formatted text. This will give the various documents required to created the text.
At the code level the curve you pick will be at the parts level but you will need to get to the parent occurrence of the part occurrence. See API help here for parentoccurrence
Attach any code attempt that you have.
Regards
Alan
