06-21-2023
10:15 AM
- Mute
- Permalink
- Report
06-21-2023
10:15 AM
Hi @BK-MTFNE,
Give this a try.
I hope this helps.
Curtis
Dim modelDoc = ThisDrawing.ModelDocument
Dim drawingViewExtension As String = System.IO.Path.GetExtension(modelDoc.FullFileName).ToLower()
' Define the title block names
Dim titleBlockIPT As String = "Production Drawing Title Block"
Dim titleBlockIAM As String = "Assembly Drawing Title Block"
Dim defaultTitleBlock As String = "DefaultTitleBlock"
' Assign the appropriate title block based on the file extension
Dim titleBlockName As String = defaultTitleBlock ' Default title block
Select Case drawingViewExtension
Case ".ipt"
titleBlockName = titleBlockIPT
Case ".iam"
titleBlockName = titleBlockIAM
End Select
' Set the title block for the active sheet
ActiveSheet.TitleBlock = titleBlockName
