- Mute
- Permalink
- Report
Hi folks!
I have the next problem, after i have added a view on my drawing i have this nice rule to automate the annonations needed for the people in the workshop to do the drilling of the holes. I attached the drawing document with a view added of a profile that needs holes.
- i click the rule
- i add the dimensions to the profile
so far so good! The dimensions are nicely added. Amazing
but then the HORROR starts. because i continue creating the drawing but when i push Control-z, it takes me all the way back to the moment i added the rule. As well als my Model Tree freezes.
Does anyone knows what is wrong with the code that it starts doing weird stuff?
i attached a sample document that shows my problem.
Here is the code:
Public Class ThisRule Private _doc As DrawingDocument Private _sheet As Sheet Private _view As DrawingView Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)() Private _centerPointIntents As List(Of GeometryIntent) = New List(Of GeometryIntent)() ' Some settings here for you to change. Private _stackedDimensions As Boolean = True Private _firstOffset As Double = 0.4 'Cm Private _offsetDimension As Double = 0.5 'Cm Sub main() _doc = ThisDoc.Document _sheet = _doc.ActiveSheet _view = ThisApplication.CommandManager.Pick( SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view") Dim transaction As Transaction = ThisApplication.TransactionManager.StartTransaction(_doc, "Generate dimensions") CreateIntentList() ' Comment out features that you dont want/need! CreateHorizontalDimensions() CreateVerticalDimensions() 'CreateMarks() AddDiameterDimensionToCircles() ' createHorizontalOuterDimension() ' createVerticalOuterDimension() i += 1 End Sub Public Sub CreateHorizontalDimensions() Dim orderedIntents = _intents.OrderBy(Function(s) s.PointOnSheet.X) Dim orderedCenterIntents = _centerPointIntents.OrderBy(Function(s) s.PointOnSheet.X) Dim pointLeft = orderedIntents.First Dim pointRight = Nothing Dim lastX = pointLeft.PointOnSheet.X Dim offset As Double = _firstOffset For Each intent As GeometryIntent In orderedCenterIntents pointRight = intent If (AreEqual(pointRight.PointOnSheet.X, lastX)) Then Continue For End If CreateHorizontalDimension(pointLeft, pointRight, offset) If _stackedDimensions Then offset = offset + _offsetDimension Else End If lastX = pointRight.PointOnSheet.X Next pointRight = orderedIntents.Last CreateHorizontalDimension(pointLeft, pointRight, offset) End Sub Private Sub CreateHorizontalDimension(pointLeft As GeometryIntent, pointRight As GeometryIntent, distanceFromView As Double) Dim textX = pointLeft.PointOnSheet.X + (pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2 Dim textY = _view.Position.Y + _view.Height / 2 + distanceFromView Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY) _sheet.DrawingDimensions.GeneralDimensions.AddLinear( pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType) End Sub Private Sub CreateHorizontalOuterDimension() Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X) Dim pointLeft = orderedIntents.First Dim pointRight = orderedIntents.Last CreateHorizontalDimension(pointLeft, pointRight, _firstOffset - _offsetDimension) End Sub Public Sub CreateVerticalDimensions() Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y) Dim orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.Y) Dim pointLeft = orderedIntents.First Dim pointRight = Nothing Dim lastY = pointLeft.PointOnSheet.Y Dim offset As Double = _firstOffset For Each intent As GeometryIntent In orderedCenterIntents pointRight = intent If (AreEqual(pointRight.PointOnSheet.Y, lastY)) Then Continue For End If CreateVerticalDimension(pointLeft, pointRight, offset) If _stackedDimensions Then offset = offset + _offsetDimension Else pointLeft = pointRight End If lastY = pointRight.PointOnSheet.Y Next pointRight = orderedIntents.Last CreateVerticalDimension(pointLeft, pointRight, offset) End Sub Private Sub CreateMarks() Dim done As List(Of GeometryIntent) = New List(Of GeometryIntent)() Dim orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.Y) Dim firstIntent = orderedCenterIntents(0) Dim secondIntent = Nothing For i = 1 To orderedCenterIntents.Count - 1 secondIntent = orderedCenterIntents(i) If (AreEqual(firstIntent.PointOnSheet.Y, secondIntent.PointOnSheet.Y)) Then CreateCenterLine(firstIntent, secondIntent) done.Add(firstIntent) done.Add(secondIntent) End If firstIntent = secondIntent Next orderedCenterIntents = _centerPointIntents.OrderByDescending(Function(s) s.PointOnSheet.X) firstIntent = orderedCenterIntents(0) secondIntent = Nothing For i = 1 To orderedCenterIntents.Count - 1 secondIntent = orderedCenterIntents(i) If (AreEqual(firstIntent.PointOnSheet.X, secondIntent.PointOnSheet.X)) Then CreateCenterLine(firstIntent, secondIntent) done.Add(firstIntent) done.Add(secondIntent) End If firstIntent = secondIntent Next For Each intent As GeometryIntent In orderedCenterIntents If (done.Contains(intent)) Then Continue For End If _sheet.Centermarks.Add(intent) Next End Sub Public Sub CreateCenterLine(pointLeft As GeometryIntent, pointRight As GeometryIntent) Dim collection = ThisApplication.TransientObjects.CreateObjectCollection() collection.Add(pointLeft) collection.Add(pointRight) _sheet.Centerlines.Add(collection) End Sub Private Sub CreateVerticalDimension(pointLeft As GeometryIntent, pointRight As GeometryIntent, distanceFromView As Double) Dim textY = pointLeft.PointOnSheet.Y + (pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2 Dim textX = _view.Position.X - _view.Width / 2 - distanceFromView Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY) _sheet.DrawingDimensions.GeneralDimensions.AddLinear( pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType) End Sub Private Sub CreateVerticalOuterDimension() Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y) Dim pointLeft = orderedIntents.Last Dim pointRight = orderedIntents.First CreateVerticalDimension(pointLeft, pointRight, _firstOffset - _offsetDimension) End Sub Private Sub AddIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean) Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace) If intent.PointOnSheet Is Nothing Then Return If onLineCheck Then If (IntentIsOnCurve(intent)) Then _intents.Add(intent) End If Else _intents.Add(intent) End If End Sub Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean Dim Geometry As DrawingCurve = intent.Geometry Dim sp = intent.PointOnSheet Dim pts(1) As Double Dim gp() As Double = {} Dim md() As Double = {} Dim pm() As Double = {} Dim st() As SolutionNatureEnum = {} pts(0) = sp.X pts(1) = sp.Y Try Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st) Catch ex As Exception Return False End Try Return True End Function Private Sub CreateIntentList() For Each drawingCurve As DrawingCurve In _view.DrawingCurves Select Case DrawingCurve.ProjectedCurveType Case _ Curve2dTypeEnum.kCircleCurve2d, Curve2dTypeEnum.kCircularArcCurve2d, Curve2dTypeEnum.kEllipseFullCurve2d, Curve2dTypeEnum.kEllipticalArcCurve2d AddIntent(DrawingCurve, PointIntentEnum.kCircularTopPointIntent, True) AddIntent(DrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True) AddIntent(DrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True) AddIntent(DrawingCurve, PointIntentEnum.kCircularRightPointIntent, True) AddIntent(DrawingCurve, PointIntentEnum.kEndPointIntent, False) AddIntent(DrawingCurve, PointIntentEnum.kStartPointIntent, False) If (DrawingCurve.ProjectedCurveType = Curve2dTypeEnum.kCircleCurve2d) Then Dim intent = _sheet.CreateGeometryIntent(DrawingCurve, PointIntentEnum.kCenterPointIntent) _centerPointIntents.Add(intent) End If Case _ Curve2dTypeEnum.kLineCurve2d, Curve2dTypeEnum.kLineSegmentCurve2d AddIntent(DrawingCurve, PointIntentEnum.kEndPointIntent, False) AddIntent(DrawingCurve, PointIntentEnum.kStartPointIntent, False) Case _ Curve2dTypeEnum.kPolylineCurve2d, Curve2dTypeEnum.kBSplineCurve2d, Curve2dTypeEnum.kUnknownCurve2d ' Unhandled curves types Case Else End Select Next End Sub Private Sub AddDiameterDimensionToCircles() If _intents.Count = 0 Then Exit Sub End If Dim intent As GeometryIntent = _intents.Item(0) Dim geo = intent.Geometry If (geo.type <> ObjectTypeEnum.kDrawingCurveObject) Then Exit Sub End If Dim curve As DrawingCurve = geo If (curve.ProjectedCurveType <> Curve2dTypeEnum.kCircleCurve2d) Then Exit Sub End If Dim rangeBox = curve.Evaluator2D.RangeBox Dim radius = (rangeBox.MaxPoint.X - rangeBox.MinPoint.X) / 2 Dim x = curve.CenterPoint.X + radius Dim y = curve.CenterPoint.Y + radius Dim textPoint = ThisApplication.TransientGeometry.CreatePoint2d(x, y) _sheet.DrawingDimensions.GeneralDimensions.AddDiameter(textPoint, intent) End Sub Private Function AreEqual(d1 As Double, d2 As Double) Return (Math.Abs(d1 - d2) < 0.000001) End Function ' Copyright 2021 ' ' This code was written by Jelte de Jong, and published on www.hjalte.nl ' ' Permission Is hereby granted, free of charge, to any person obtaining a copy of this ' software And associated documentation files (the "Software"), to deal in the Software ' without restriction, including without limitation the rights to use, copy, modify, merge, ' publish, distribute, sublicense, And/Or sell copies of the Software, And to permit persons ' to whom the Software Is furnished to do so, subject to the following conditions: ' ' The above copyright notice And this permission notice shall be included In all copies Or ' substantial portions Of the Software. ' ' THE SOFTWARE Is PROVIDED "AS IS", WITHOUT WARRANTY Of ANY KIND, EXPRESS Or IMPLIED, ' INCLUDING BUT Not LIMITED To THE WARRANTIES Of MERCHANTABILITY, FITNESS For A PARTICULAR ' PURPOSE And NONINFRINGEMENT. In NO Event SHALL THE AUTHORS Or COPYRIGHT HOLDERS BE LIABLE ' For ANY CLAIM, DAMAGES Or OTHER LIABILITY, WHETHER In AN ACTION Of CONTRACT, TORT Or ' OTHERWISE, ARISING FROM, OUT Of Or In CONNECTION With THE SOFTWARE Or THE USE Or OTHER ' DEALINGS In THE SOFTWARE. End Class
- Mute
- Permalink
- Report
The issue is that your code starts a transaction, but never finishes it. Change your Sub main() to the following and the issue should go away.
Sub main()
'Start the transaction
Dim oTransaction As Transaction = ThisApplication.TransactionManager.StartTransaction(_doc, "Generate dimensions")
CreateIntentList()
'CreateMarks()
i += 1
'End the transaction
oTransaction.End()
End Sub
- Mute
- Permalink
- Report
