WCrihfield
in reply to: denis.semeniuc
Sure.  Which way would you prefer the rule to work:
  • The 'new' drawing will be the 'active' drawing when you run the rule, then you open the template drawing (using open dialog) and copy sheets from the template into the new/active drawing.
  • The template drawing will be the 'active' drawing when you run the rule, then you open the 'other' drawing (using open dialog), and copy the sheets from the template to the 'other' drawing.
  • The 'new' drawing will be the 'active' drawing when you run the rule, and the template file's full file name is hard coded into the rule (no open dialog needed), so it will invisibly open the template in the background, and copies the sheets to the active drawing.
Wesley Crihfield
(Not an Autodesk Employee)
