JelteDeJong
in reply to: johnPGNFG
I wanted to do something similar but I never found a good solution. If I need to find a point both in the flatpattern and the folded model then I make a very small hole in the folded model at the point that I need to find. Then I look op that hole in the flatpattern. (If anyone knows a better solution I would like to know about it.) But I see that you want text. If you are working with Inventor 2023 or newer that you have a special command for this. Have a look at the Mark command.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-8B8DD53E-2E54-43D4-8E7B-7B90CAEB4BFA
It has some interesting extra options.
Jelte de Jong
Blog: hjalte.nl - github.com
