Curtis_Waguespack
in reply to: romu51
Hi @romu51
I don't think that would be possible with iLogic ( you could likely do it by writing a small add-in, but that seems like overkill).
You could right click on the Dimension button and choose "Add to Quick Access Toolbar" and then just use the Dimension tool from there.
You could also add the Dimension button the Place Views tab on the User Command panel
( Tools tab > Customize button )
I hope this helps.
Curtis
