A.Acheson
in reply to: Shag_Bore
Hi @Shag_Bore
Unfortunately a lot of the Parts list options are not exposed to the API so to get your effect would be a long workaround. You would need to look into the active view rep of the view, get all the parts and qty's for this view rep then loop through the the partslist row referenced document  matching to the view rep list then and if found overwrite the partlist qty with that from the list. You will end up with every qty overridden and really a mess for anyone coming behind wanting to know where the values came from.
See this post on future improvements form the inventor idea. It won't help your future  initial question but for the future inventor version.
Regards
Alan
