supriya_chaugule
333 Views, 2 Replies
Find the adjacent faces of given edge or face
Hiii.....I need to find the adjacent facec of edge or given face to do the chamfer .Can anybody suggest the code for the same?
Hi @supriya_chaugule . Here's a code example to get a list of faces.
Sub main()
	Dim oDoc As PartDocument = ThisApplication.ActiveDocument
	Dim oFace As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Pick the face")
	If oFace Is Nothing Then Exit Sub
	Dim listFaces As New List(Of Face)
	listFaces.AddRange(GetAdjacentFaces(oFace))
End Sub
Private Function GetAdjacentFaces(oFace As Face) As List(Of Face)
	For Each oEdge As Edge In oFace.Edges
		For Each oEdgFace As Face In oEdge.Faces
			If Not oEdgFace Is oFace Then listFaces.Add(oEdgFace)
		Next
	Next
	Return listFaces
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Thanks @Andrii_Humeniuk  For the solution.
