p.kaminskiG7KX4
294 Views, 4 Replies
Dimensions calculator
I am asking you for help. Is it possible to create a calculator that will export, for example, an excel list with the dimensions of a rectangle circumscribed by an ellipse? I have created a layout as shown in the picture below. I have an outlined rectangle on an ellipse. The only controlled value is the angle of the ellipse. I want to be able to get the width and height values โ€‹โ€‹of the rectangle for this layout, depending on the inclination of the ellipse. In the range of 0 to 90 degrees. It can be a list in excel, a text file, etc.
Thank you for help.
