p.kaminskiG7KX4
292 Views, 4 Replies
Dimensions calculator
I am asking you for help. Is it possible to create a calculator that will export, for example, an excel list with the dimensions of a rectangle circumscribed by an ellipse? I have created a layout as shown in the picture below. I have an outlined rectangle on an ellipse. The only controlled value is the angle of the ellipse. I want to be able to get the width and height values ​​of the rectangle for this layout, depending on the inclination of the ellipse. In the range of 0 to 90 degrees. It can be a list in excel, a text file, etc.
Thank you for help.
Hi @p.kaminskiG7KX4 . Here is an example of code that searches all sketches for ellipses and measures their dimensions along the X and Y axes:
Private Sub Main()
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If Not TypeOf oDoc Is PartDocument Then Exit Sub
	Dim oPDoc As PartDocument = oDoc
	Dim oUOfM As UnitsOfMeasure = oPDoc.UnitsOfMeasure
	Dim oSketches As PlanarSketches = oPDoc.ComponentDefinition.Sketches
	Dim dMinX, dMinY, dMaxX, dMaxY As Double
	For Each oSketch As PlanarSketch In oSketches
		If oSketch.SketchEllipses.Count = 1 Then
			Dim oEllipse As SketchEllipse = oSketch.SketchEllipses.Item(1)
			dMinX = oUOfM.ConvertUnits(oEllipse.RangeBox.MinPoint.X, kCentimeterLengthUnits, oUOfM.LengthUnits)
			dMinY = oUOfM.ConvertUnits(oEllipse.RangeBox.MinPoint.Y, kCentimeterLengthUnits, oUOfM.LengthUnits)
			dMaxX = oUOfM.ConvertUnits(oEllipse.RangeBox.MaxPoint.X, kCentimeterLengthUnits, oUOfM.LengthUnits)
			dMaxY = oUOfM.ConvertUnits(oEllipse.RangeBox.MaxPoint.Y, kCentimeterLengthUnits, oUOfM.LengthUnits)
			MessageBox.Show("X = " & Abs(Round(dMaxX - dMinX, 3)), oSketch.Name & ", Size X")
			MessageBox.Show("Y = " & Abs(Round(dMaxY - dMinY, 3)), oSketch.Name & ", Size Y")
		End If
	Next
End Sub
 You can see how to create an excel file and write information in it here.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Dim a As Inventor.PartDocument = ThisDoc.Document
Dim b As Inventor.PartComponentDefinition = a.ComponentDefinition
Dim c As Inventor.Sketch = b.Sketches.Item(1)
Dim b2d As Inventor.Box2d = c.SketchEllipses.Item(1).RangeBox
MsgBox(b2d.MinPoint.X)
MsgBox(b2d.MinPoint.Y)
MsgBox(b2d.MaxPoint.X)
MsgBox(b2d.MaxPoint.Y)
Dim dX As Double = b2d.MaxPoint.X - b2d.MinPoint.X
Dim dy As Double = b2d.MaxPoint.Y - b2d.MinPoint.Y
MsgBox(dX * 10 & " " & dy * 10)'
'AND WRITE THESE TO EXCEL??
Arthur Knoors
Autodesk Affiliations:
Thank you, that is what I want. I think about find position of point crossing rectangle and ellipse. Can we add dimensions of the point, as well?
Thank you. Yes,   it would be nice to export them to excel file.
