dypro
in reply to: WCrihfield
Hello again @WCrihfield thank you for keep trying.
Now it does work when there is no revision date and it doesn't prompt the error anymore, but it prompts a revision date...
06/08/2022 is the creation date, so the revision date would be better empty than that, it only will lead to error.
I'm guessing that is the "minimum value" you talk about... there is a way to make it just not appear in that case?
When you use the 'date' in the iproperties there is a box you can uncheck to make it go to "".
Not sure how difficult is to replicate that with ilogic. Maybe something like, "if the date going to be displayed is nothing uncheck that box" or "if your date is prior to the 1900, uncheck the box" ?
The normal thing to do would be:
uncheck the box
hit modify
the iproperty does exist but has been emptyed so just hit apply or accept and whe have it.
Again, not sure how difficult is to achieve this in ilogic
