@WCrihfield Thanks for the snippet. Unfortunately I realized after originally posting that I just need the suffix (model state name) to be added to the corresponding model states' part number iproperty field. I edited your last two lines and it doesn't seem to generate the model states. When I ranit on a template that I already have created the model states, it does populate the finished part number custom iproperty with the model state name but doesn't include the part number. Now that I'm not needing it to write to the custom iproperty and rather write it to the part number iprop of the active model state, where should I alter the code at?
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
