rmostertRGQ8T
244 Views, 2 Replies
Save loop when trigger form 'Before save'
Hej, I'm making a Form that let you fill in some iProperties and Revision info (custom properties) when you save.
I try to do this by trigger an ILogic rule that shows the form 'before saving'. But this does not work as i would like, since the save happens after the rule but BEFORE the form is done. So the info is not saved.
So i thought "Easy, i let the form save when close."  But that save will trigger the rule to show the form again!!
Is there a way to trigger the form 'before save' and ACTUALLY fill the form BEFORE the save happends, so the filled in info in the form is saved with it?
