06-06-2023
01:16 PM
- Mute
- Permalink
- Report
06-06-2023
01:16 PM
Hi, I am trying to highlight components on a drawing view as solid red using client graphics. I am using the componentoccurrence of the assembly in the drawing view to create surfacegraphics and display that. It is working where it will display what i was expecting but I am stuck trying to position it, it defaults to the center of the view. I can move it with SetTransformBehavior but I can't get an accurate position based on the part itself.
So my question is how do we get the part origin point in drawing/drawing view space using a componentoccurrence
This loops through each view
For Each oDrawingView In sparesSheet.DrawingViews
Try
oDataSets = oDrawingView.GraphicsDataSetsCollection.Item("CG_Test3")
oDataSets.Delete
oDataSets = oDrawingView.GraphicsDataSetsCollection.Add("CG_Test3")
Catch
End Try
Try
oClientGraphics = oDrawingView.ClientGraphicsCollection.Item("CG_Test3")
oClientGraphics.Delete
oClientGraphics = oDrawingView.ClientGraphicsCollection.Add("CG_Test3")
Catch
End Try
Dim oModelDoc As Document
oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
TraverseAssembly(oModelDoc.ComponentDefinition.Occurrences)
iLogicVb.UpdateWhenDone = True
Next
Here is the part actually creating client graphics within the traverseassembly loop
Dim oLineNode As GraphicsNode
oLineNode = oClientGraphics.AddNode(1)
Dim oTransientBRep As TransientBRep
oTransientBRep = ThisApplication.TransientBRep
'By Transient Brep Class To copy the surface body
Dim oBody As SurfaceBody
oBody = oTransientBRep.Copy(oOcc.Definition.SurfaceBodies.Item(1))
' Create client graphics based on the transient body
Dim oSurfaceGraphics As SurfaceGraphics
oSurfaceGraphics = oLineNode.AddSurfaceGraphics(oBody)
oSurfaceGraphics.Color = oColor
oSurfaceGraphics.BurnThrough = True
'oSurfaceGraphics.SetViewSpaceAnchor(oTG.CreatePoint(0,0,0), oTG.CreatePoint2d(10,10), ViewLayoutEnum.kBottomLeftViewCorner)
Dim temp As WorkPoint
temp = oOcc.Definition.WorkPoints(1)
Dim tempproxy As WorkPointProxy
oOcc.CreateGeometryProxy(temp, tempproxy)
oSurfaceGraphics.SetTransformBehavior(oTg.CreatePoint(tempproxy.Point.X, tempproxy.Point.Y, tempproxy.Point.Z), DisplayTransformBehaviorEnum.kFrontFacing)
