kv5053545
in reply to: A.Acheson
hi @A.Acheson,
this is the code i've been using, I still can't figure out how to know which side the occurrence is on (right,left,up or down), in both drawings i'm using the same code only one has more walls(occurrences) than the other one.
Dim drawingDoc As DrawingDocument = ThisApplication.ActiveDocument
' Loop through each sheet in the drawing document
For Each sheet As Sheet In drawingDoc.Sheets
	' Loop through each view on the sheet
For Each view As DrawingView In Sheet.DrawingViews
    If View.name = "VIEW1" Then
        ' Check if the view is an assembly view
        ' Get the assembly document for the view
        Dim asmDoc As AssemblyDocument = View.ReferencedDocumentDescriptor.ReferencedDocument
        ' [Loop through each assembly component
        For Each comp As ComponentOccurrence In asmDoc.ComponentDefinition.Occurrences
            Dim Componente = comp.Name
            Dim BuscarWalls As String = "Wall"
            If Componente.Contains(BuscarWalls) = True Then
                ' Add a dimension to the component if the component name contains "Wall"
               Dim ShGeneral = ThisDrawing.Sheets.ItemByName("General:1")
               Dim genDims = ShGeneral.DrawingDimensions.GeneralDimensions
               Dim VIEW1 = ShGeneral.DrawingViews.ItemByName("VIEW1")
			   Dim WPl_Wall_FlangeLeft = VIEW1.GetIntent(comp.Name,"WPl_Wall-FlangeLeft")
               Dim WPl_Wall_FlangeRight = VIEW1.GetIntent(comp.Name, "WPl_Wall-FlangeRight")
''[Find a way to set the dimension depending on where the coordinate is located
''[Declare variables for the dimension position
Dim oMatrix As Matrix = comp.Transformation
Dim x As Double = oMatrix.Cell(1, 4)
Dim y As Double = oMatrix.Cell(2, 4)
Dim z As Double = oMatrix.Cell(3, 4)
Dim dimX As Double
Dim dimY As Double
 If x < 0 And y < 0 And z < 0 Then
    dimX = 1.10
	dimY = -0.02
Else If x > 0 And y < 0 And z < 0 Then
   dimX = -0.03
	dimY = 1
Else If x > 0 And z > 0 And y < 0 Then
	dimX = 0.07
	dimY = 1.02
Else If z > 0 And x < 0 And y < 0  Then
	dimX = 1.03
	dimY = 0
End If
                Dim linDim1 = genDims.AddLinear("Width_" & Componente, VIEW1.SheetPoint(dimX, dimY), WPl_Wall_FlangeLeft, WPl_Wall_FlangeRight)
            End If
        Next
    End If
    Next
   Next
