06-06-2023
01:49 AM
- Mute
- Permalink
- Report
06-06-2023
01:49 AM
I copied and pasted your code, but i am getting the same result.I would like to mention that I am making an AddIn so I slightly had to correct the code so a button is triggering the function.
Private Sub Button_test_Click(sender As Object, e As EventArgs) Handles Button_test.Click
Try
Dim oDoc As AssemblyDocument = g_inventorApplication.ActiveDocument
Dim oColl As ObjectCollection = g_inventorApplication.TransientObjects.CreateObjectCollection
Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
Call GetAllPatterns(oDef.OccurrencePatterns, oColl)
Call GetAllOccs(oDef.Occurrences, oColl)
If oColl Is Nothing Then Exit Sub
For Each obj In oColl
PrintToLog(obj.Name)
Next
oDoc.SelectSet.SelectMultiple(oColl)
'oDoc.Rebuild()
'oDoc.Update()
Catch ex As Exception
MsgBox(ex.ToString())
End Try
End Sub
Private Sub GetAllOccs(oOccs As ComponentOccurrences, ByRef oColl As ObjectCollection)
For Each oOcc As ComponentOccurrence In oOccs
If oOcc.Suppressed Then Continue For
If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
Dim oOccDef As AssemblyComponentDefinition = oOcc.Definition
Dim oOccDoc As AssemblyDocument = oOccDef.Document
Call GetAllPatterns(oOccDef.OccurrencePatterns, oColl)
If oOcc.SubOccurrences Is Nothing Then Continue For
If oOcc.SubOccurrences.Count <> 0 Then
Call GetAllOccs(oOcc.SubOccurrences, oColl)
End If
End If
oColl.Add(oOcc)
Next
End Sub
Private Function GetAllPatterns(oOccsPatt As OccurrencePatterns, ByRef oColl As ObjectCollection)
For Each oOccPatt As OccurrencePattern In oOccsPatt
' Work with visible
oOccPatt.Visible = False
' Work with suppress
oOccPatt.Suppress(True)
'Select patterns
oColl.Add(oOccPatt)
Next
End FunctionIf I leave the line where it should suppress the patterns it gives an error: Public member 'Suppress' on type 'RectangularOccurrencePattern' not found.
If I comment out that line it gives an error at the 'SelectSet.SelectMultiple' where it gives an error: The parameter is incorrect.
The visibility line is ignored every time.
I need to point out that this problem persists only on lower level patterns. If I only look for top level patterns it works fine as expected.
