Andrii_Humeniuk
in reply to: jaka73LU2
Hi @jaka73LU2 . Wrote for you an example of obtaining all patterns (in the main assembly and subassemblies).
Private Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Call GetAllPatterns(oDef.OccurrencePatterns, oDoc.DisplayName)
	Call GetAllOccs(oDef.Occurrences)
End Sub
Private Sub GetAllOccs(oOccs As ComponentOccurrences)
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Dim oOccDef As AssemblyComponentDefinition = oOcc.Definition
			Call GetAllPatterns(oOccDef.OccurrencePatterns, oOcc.Name)
			If oOcc.SubOccurrences Is Nothing Then Continue For
			If oOcc.SubOccurrences.Count <> 0 Then
				Call GetAllOccs(oOcc.SubOccurrences)
			End If
		End If
	Next
End Sub
Private Function GetAllPatterns(oOccsPatt As OccurrencePatterns, sNameParent As String)
	For Each oOccPatt As OccurrencePattern In oOccsPatt
		MessageBox.Show(oOccPatt.Name, sNameParent)
	Next
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
